Salta al contenuto principale
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
20 Domande Visualizza tutte
Wet Samsung j7 is not working properly
what do I do if my phone fell in the water? it is not working properly. it is very difficult to use it because it presses random buttons and sometimes freezes until I turn it off and back on. PLEASE HELP.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@anadelmar first do not turn on your phone, charge it or try to connect it in any way. Remove the battery as soon as possible from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points are still pertinent to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Aggiungere immagini ad una domanda for that.
Once it is properly cleaned, replace the battery and reassemble your phone. then you can properly troubleshoot.
Immagine iPhone
Guida
Riparazione danno da liquidi iPhone
Difficoltà:
Difficile
1 - 2 hours
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Punteggio 1
If you open up the backing and let the motherboard dry it may help.
Punteggio 0
Aggiungi la tua risposta
Ana DelMar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,117
