Salta al contenuto principale
Rilasciato a maggio 2012, identificabile dal numero di modello J2011-03-US.
Stereo cable entry broken...How to fix it?
The entry to plug the stereo cable on my jambox is brocken. The sound quality is bad if I connect with the cable. With bluetooth, the sound is good. I would like to fix it. How can I do???? Please help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sadly Jawbone the company is not well these days: Jawbone is going out of business. Once they were quite innovative with there small speakers and bluetooth headphones.
Sadly, parts are just not available from them. I have seen a few eBay listings of some parts which is where you'll need to look.
Here's the IFIXIT guide to gain access to the assembly: Jawbone Big Jambox Micro USB Port Replacement
If you can desolder the jack socket you might be able to locate an off the shelf replacement at a good electronics parts supply house.
Maybe the better answer here is not to fix it and just use the Bluetooth connection.
Or, look at getting a new speaker. I had two Jawbone units both died, I went out and bought two UE Boom2's which I think are quite good!
Punteggio 1
Aggiungi la tua risposta
elsdoue sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 20
Tutti i Tempi: 342
