Salta al contenuto principale
Questo computer è stato rilasciato da Asus nel 2014.
How do I reinstall the system?
I want to reboot my computer, it's slow and the storage is full, even though I don't have much stuff on there. How do I reboot it? I've done it once before, but it was long ago, so I can't remember. The computer is a bit over a year old.
Questa è una buona domanda?
Punteggio 4
6 Commenti:
What OS version do you have installed?
da Condividi
I have Windows
da Condividi
Did you empty your recycling box?
da Condividi
Hi @@feliciaspyan using windows 10 ? If so there is should be option by the OEM inside to reset your pc.
Try This
https://www.laptopmag.com/articles/reset...
da Condividi
How do I reset it without logging in
da Condividi
Mostra 1 altri commenti
Aggiungi un commento
3 Risposte
As indicated by Augustine, use the link to laptopmag.com.
MAKE SURE YOU HAVE ANY FILES YOU WANT TO KEEP/SAVE COPIED TO A SAFE LOCATION (thumb drive, external hard drive, DVD ROM, etc).
  1. Click Start
  2. Type in "Settings" and click "Settings"
  3. Click "Update and Recovery"
  4. Select "Recovery" from the left-side menu
  5. Under "Reset this PC" click "Get Started"
  6. Make sure your files are backed up, select "Remove Everything"
  7. Click the "Just remove my files" option - This should be sufficient for your needs
  8. Click "Next"
  9. Click "Reset"
  10. Click "Continue"
I believe from this point, you should be back to square one and the initial Windows 10 setup wizard will walk you through the rest of the setup.
If you get stuck, don't be afraid to ask more questions.
Punteggio 0
  1. turn power On
  2. press F9 many times. You will have recovery mode.
Punteggio 0
Je vs conseil de faire une nouvelle installation c'est plus sécurisé
Punteggio 0
Aggiungi la tua risposta
Felicia Birgersson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 8,789
