Salta al contenuto principale
Rilasciato nel 2010, il Sony Vaio SVE11B11L è noto anche come parte della serie Sony Vaio E. Prodotto dalla Sony, è associato ad altri modelli, come: SVE11125CXB, SVE11125CXW, SVE11135CXB e SVE11135CXW.
Not didating the hard drive
i removed the cmos battery from the mother board after fixing it back, when i tried to on it, i discovered that the system is no longer dictating the hard drive, so in this case, what do i do?
Questa è una buona domanda?
Punteggio 0
2 Commenti
tanx so much, but i have done that sir, but the issue here is that, the system is not entering BIOS setup, i have been using my F2 command but it has refused to enter setup, is still showing operating system not found, so what do i do next
da
Remove the computer battery and the CMOS battery for 30 minutes, then replace both and try again to enter Setup.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Boot to the BIOS, by Tapping the F2 key when you Power On. When the BIOS screen come up, scroll to the "Disk #1" setting and press Enter. It should find your hard drive. Save and Exit, and your drive should now be the default.
Good luck,
Russ
Punteggio 1
Aggiungi la tua risposta
onyebuchiadieze sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 25
Tutti i Tempi: 386
