Salta al contenuto principale
Rilasciato ad agosto 2013. Identificabile dal numero di modello Z796C
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
Questa è una buona domanda?
Punteggio 9
4 Commenti
I also have this problem and can not find an answer.
da
Yes help me remove message
da
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
da
My phone doesn't allow any contact to save
da
Aggiungi un commento
3 Risposte
Risposta più utile
go into your setting and enable the permissions for your contacts..should be in application settings
Punteggio 5
4 Commenti:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
da
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
da
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
da
How do I find the contact applications so I can all he permissions?
da
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
Punteggio 0
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
Punteggio 0
1 Commento:
On cell majestic. Zte
da
Aggiungi la tua risposta
Elena Vaccaro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 25
Tutti i Tempi: 8,161
