Salta al contenuto principale
Schermo Full HD da 5,9 pollici 1080p, processore quad-core da 1,7 GHz e batteria da 3300 mAh
earpiece speaker and audio jack
The earpiece speaker doesn't work, either does the audio jack on my HTC One Max HTC6600LVW. If I replace just the earpiece speaker would the audio jack work again? Or do I have to replace the "Audio Daughterboard" to get them both to work again?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Depends on where the problem is located but, typically they are two different components. Have you checked the headphone jack to make sure there is not damage? If the phones detects something plugged in, it will route sound to that output.
Punteggio 1
Aggiungi la tua risposta
sam jacobs sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 12
Tutti i Tempi: 220
