Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 era a quel tempo il top della gamma Galaxy. La versione con schermo curvo è nota come Galaxy S6 Edge.
487 Domande Visualizza tutte
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
da
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Sostituzione batteria Samsung Galaxy S6
Sostituzione scheda figlia Samsung Galaxy S6
Immagine Samsung Galaxy S6 Batteria
Guida
Difficoltà:
Difficile
40 minutes - 1 hour
Immagine Samsung Galaxy S6 Scheda figlia
Guida
Difficoltà:
Difficile
45 minutes - 2 hours
Punteggio 0
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Punteggio 0
Aggiungi la tua risposta
Amy ford sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 18
Tutti i Tempi: 152
