Salta al contenuto principale
Un desktop all-in-one portatile con touch screen prodotto nel 2013 da Dell. È possibile trovare il numero di modello W01A controllando il piede di supporto destro del dispositivo.
My display setting somehow got changed
I came back to my computer which was just in sleep mode, and the picture is not full screen. There is about two inches on each side that are not used and I can't figure out what I did or if something accidentally got changed. I restarted the computer and looked for any settings but can't figure it out...Help Please!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Go into device manager and reset your display. Should fix the issue. First, though go into your screen resolution and check to see what the resolution is set as. Sometimes it can be as simple as hdmi cord not connected or vga cord. Unplug then replying back in.
Punteggio 1
1 Commento:
Thank you..thank you..thank you! Somehow the resolution had gotten changed.
da
Aggiungi la tua risposta
lynn rebbing sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 19
Tutti i Tempi: 354
