Salta al contenuto principale
battery contacts points missing in cover
how can I replace the battery contacts points in the cover
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@fasteddywilson, edmund, Normally the battery door assy would be replaced as it will have the contacts molded into it I believe. Below is a guide that will show how to disassemble camera to access battery door hinge pin to enable changing of battery door. Also a couple links to replacement battery door assy. which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Sostituzione del corpo macchina della Canon PowerShot A620
http://www.procamerarepair.com/CANON-POW...
http://www.ebay.com/itm/GENUINE-CANON-A6...
Immagine
Punteggio 2
Aggiungi la tua risposta
edmund wilson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 8
Tutti i Tempi: 588
