Salta al contenuto principale
La guida di riparazione per Mercedes W115 copre sia i modelli W114/W115 tra cui 200/200D, 220/220D, 230.4/230.6/240D, 250, 280, 300D e diverse altre varianti Station Wagon, Coupé e Berlina dal 1968 al 1976.
replacing driver side check strap
I need to replace the door check strap in my 76 300d W115. Took door panel off, but you can't get the check strap out without taking the entire window assembly out, it appears to me.
am I missing something on replaceing, and what is the proper procedure to removing the window etc.
need some advice on this.
thanks
Philip
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@yadkin2002, Philip, I do not believe/not positive the entire window should have to come out to change the door strap, you should have to remove the pin and bolts and may have to turn(manipulate) the old strap to remove from door cavity or possibly have to loosen front window guide/track. Just to add a little to OT post, the video links(not your exact model) but may help in the removal of check strap. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=m3_NggBa...
https://www.youtube.com/watch?v=R0U3VNbb...
https://mercedessource.com/store/mercede...
Punteggio 3
Aggiungi la tua risposta
Philip sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 644
