Salta al contenuto principale
Annunciato a luglio 2015, è il telefono di punta di Motorola. È dotato di una fotocamera da 21 megapixel, uno schermo LCD IPS TFT da 5,7 pollici con risoluzione 1440 x 2560 Quad HD. Numeri di modello XT1570, XT1579, XT1575 e XT1578.
Power Button Not working after screen replacement
I recently changed the screen on 2 Motorola Moto X pure edition, Because it was cracked but after replacement the power button doesn't work anymore. I wonder if that could be a defect on the screen I bought. Or if I did something wrong. I followed a online guide changing everything. And Both screen bought from the same seller won't power on. It does light up when I charge just not able to tun it on. what do I have to do ?
Questa è una buona domanda?
Punteggio 1
1 Commento
Did you ever figure this out or solve it?
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
I had the same problem - my power and volume buttons stopped working after replacing the battery.
Refer to step 8 here, specifically the 2nd screenshot (2 of 3). I had to reseat my power/volume flex - I did not have to reseat the connector to the board.
The 2nd screenshot shows a cable that could have come loose. Mine was glued down and taped, but had still come loose (probably while heating the phone up to take the back plate off).
I used long thin pliers to peal the clear tape, reseat the flex, and put the tape back on again. The phone works great now!
Punteggio 2
1 Commento:
Same problem and same resolution, but with Moto Z Force Edition. Thanks!
da
there is a small rubber cover on the upper left hand side of the back plate after you close the phone back up. If you remove the cover it exposes a ribbon cable and connector the you can push to connect back to the main board. There is another one near the bottom for the same purpose to connect the battery.
I found and reconnected the one near the bottom but I missed the connector in the top left. The phone exhibited similar behavior: screen lights up when plugged in but power button doesn't respond. Hopefully that is also your issue. Hope that helps.
Connector locations
Punteggio 1
I have same problem,after screen replacement, but i dont know where is this place. Where is 2 from 3 screen? Please help.
Punteggio 0
Aggiungi la tua risposta
matheusphillipemuniz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 35
Tutti i Tempi: 4,739
