Salta al contenuto principale
Un Chromebook robusto progettato per l'uso educativo, con porte e cerniere rinforzate, tasti anti-rimozione, touchpad sigillato e 9,5 ore di autonomia della batteria.
Why won't my touchpad respond?
I can turn on the laptop and use the keyboard but every time I try to move the cursor around it still doesn't move. Once in a while if i keep trying I may get a very slight movement.
Questa è una buona domanda?
Punteggio 2
1 Commento
Student Question
da
Aggiungi un commento
2 Risposte
I had this problem too. Your touchpad is most likely partially disconnected inside the device. I fixed it easily by opening up the Chromebook and reconnecting the touchpad to the motherboard. This can happen when your Chromebook experiences a drop or a hard hit.
Punteggio 1
8 Commenti:
So you guys joined the site the same day and join the same 4 man group, post about the same device and comment on each others posts?
You guys just really into the N21 or is there another angle here?
da
Hi @thethirdtwin ,
They may be students doing projects under the auspices of ifixit, learning how to answer technical questions.
That is usually the case when you see schools mentioned in their profile
When I notice that I leave the answering to them unless it is totally wrong ;-)
You may also notice that the moderators leave a comment of 'student question' if they spot it first
da
I figured as much, but they're answering each other questions which I thought was weird. But if you've seen this before I'll leave them to it.
da
Fair enough.
I only take more notice if they don't have a 'school' mentioned in their profile (which can happen) and if their answers make no sense at all, are totally misleading even malicious, are rude etc etc.
da
@thethirdtwin yes those are indeed students. You can easily identify them by clicking on their "avatar" where you notice that their team is "Cal Poly, Team S21-G2, Livingston Spring 2017" Anytime you notice weird things like this, double check. If they are not students, then you know we'll deal with it. Thanks for being vigilant
da
Mostra 3 altri commenti
Risposta più utile
Can you click it down? If not the screws may be too tight. Also try powerwashing it as it could be softwere. As a last resort and the most likely cause open it up. The ribbon cable probably wiggled loose.
Punteggio 1
Aggiungi la tua risposta
Andrew Luong sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 2,979
