Salta al contenuto principale
Questo modello HP è stato rilasciato nel 2012. Gli aggiornamenti includono uno schermo antiriflesso da 15,6" e un lettore impronte digitali.
bootmgr image is corrupted. the system cannot boot
yesterday i have reinstalled windows 7 professional and was working fine till midnight but today i am getting below errors in my laptop while starting.
1. bootmgr image is corrupted. the system cannot boot
2.Boot Device not found
3.Werfault.exe error
4.taskhost.exe error
screenshot attached for reference.
Questa è una buona domanda?
Punteggio 0
3 Commenti
after fresh installation still same problem..
da
There is no screenshot. Are you sure you posted it?
da
check the below link for screenshots..
https://www.dropbox.com/sh/cvp50tjg5huds...
da
Aggiungi un commento
2 Risposte
Risposta più utile
get a windows cd(any version) . Click repair option when you boot with the cd (don't click install).
Click Advanced options and select cmd.
Run the following command- bootrec /fixmbr
Reboot. if still not working you will need to clean install your windows ie. delete all the partitions and make new one. It can be done with the Custom installation option while installing windows.
Punteggio 2
1 Commento:
thanks... already started taking backup from HDD so that i can fully format and create new partition.
da
bootmgr image is corrupt. the system cannot boot.
Punteggio 0
Aggiungi la tua risposta
Sushil sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 1,481
