Salta al contenuto principale
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
Cup is not getting full
Doesn't always brew a full cup
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta più utile
@diente possibly a clogged needle valve. Check this guide to see if you can clean it
Punteggio 4
1 Commento:
I thought I had everything cleaned until I read this post. I realized that I had debris in the check valve that was causing sputtering and my cups not filling. Also I would get the 'DESCALE' lamp to illuminate after a few cups. Thanks for the post. You just saved our shop time and money.
da
Hey @diente this video has a clever solution to your problem.
Here is the video.
-Let me know if this helps.
Punteggio 1
1 Commento:
I was hoping to see it function after this fix. Also waiting for the bottom to eject a DVD disk.
da
Aggiungi la tua risposta
Mary Vindiola sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 21
Tutti i Tempi: 1,053
