Salta al contenuto principale
La Nikon D5200 è una fotocamera DSLR con innesto F dotata di sensore di immagine CMOS in formato DX da 24,1 megapixel. La D5200 ha una risoluzione massima di 6000x4000 ed è in grado di registrare video a 1080p.
Problem with image size
A friend has this camera and so do I. We both have the image size set on RAW and L. My photos have a high resolution of 6000 x 4000 and hers are at 640x427. We cannot figure out why her photos are so small. Would this be a camera defect?
Questa è una buona domanda?
Punteggio 0
2 Commenti
When she uploads the photos in Lightroom, all come in at 640x427 297Kb. She is not using video.
da Condividi
Your Lightroom is probably set wrong. That's thumbnail size. Change her upload settings to full resolution.
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
That resolution isn't even possible with that camera. However, 640x424 is a supported video resolution. Are you sure your not looking at the video setting? If not, what is the resolution of your pictures based on what your computer says? Good luck.
Punteggio 1
3 Commenti:
Also, you need to try a system reset on the camera. It should be in the menu with the wrench.
da Condividi
I might not have the size exactly right, but all of the photos she uploads into Lightroom are a small pixel size, and about 297KB. All the settings on the camera look right, image quality is RAW, and size is L. But the photos upload very small.
da Condividi
Something is wrong. What resolution is the image size set to?
da Condividi
Aggiungi la tua risposta
abutts22 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 5
Tutti i Tempi: 502
