Salta al contenuto principale
Il controller wireless Xbox 7MN-0001, prodotto da Microsoft Corporation, è il controller più utilizzato per la console di gioco Xbox e può essere utilizzato anche su PC.
Broke LT and RT holders how do I replace it?
Immagine
Immagine
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Questa è una buona domanda?
Punteggio 3
1 Commento
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
da
Aggiungi un commento
6 Risposte
Risposta più utile
https://www.youtube.com/watch?v=NZp8Rcik...
Punteggio 2
1 Commento:
Thanks for that
da
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Sostituzione motorini vibrazione del Controller Wireless Xbox One
Sostituzione pulsanti Xbox One Wireless Controller
I hope these help!
Thanks,
Keegan
Immagine Xbox One Wireless Controller Model 1537 Motorini di vibrazione nei grilletti
Guida
Difficoltà:
Difficile
15 - 20 minutes
Immagine Xbox One Wireless Controller Model 1537 Pulsanti
Guida
Difficoltà:
Difficile
30 minutes - 1 hour
Punteggio 1
3 Commenti:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
da
Okay I see, so if you look back in to the link Sostituzione motorini vibrazione del Controller Wireless Xbox One it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
da
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
Punteggio 0
I need a LT trigger spring
Punteggio 0
Immagine
How to take this off lt button
Punteggio 0
1 Commento:
Same here, my rigger holder is broken too
da
My left triggers has came out of the socket please help
Punteggio 0
Aggiungi la tua risposta
J Angel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 48
Tutti i Tempi: 30,951
