What screwdriver does the inside take?
I have the iPhone screwdriver but that doesn't work
Questa è una buona domanda?
@turtlj ,Turtl Johnson, From the partial disassembly link below, these are the screw types mentioned.
17 screws from the board using a T3 bit on your screw driver. Or, use a T4 bit if the screw is slightly stripped.
4 silver screws on the top and bottom are 4.0mm Phillips #00, and the 13 black screws around the sides are 3.0mm Phillips #00.
Using a T3 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Sostituzione della fotocamera posteriore del Motorola Droid Turbo 2
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 4
Tutti i Tempi: 1,052
1 Commento
that's a pretty vague question.
do you have a picture of what youre talking about?
da Logixal
