Salta al contenuto principale
Sony Xperia Z4 (conosciuto come Sony Xperia Z3+ in Europa). Smartphone con display da 5,20 pollici 1080x1920 alimentato da un processore da 1,5 GHz, 3 GB di RAM e fotocamera posteriore da 20,7 megapixel. È stato rilasciato nel 2014.
Difference of back panels Z3+ and Z3
I broke back panel of my Sony XPERIA Z3+. In my country they don't repair XPERIA Z3+ because that phone is not selling in that region. I can't find oem back panel for XPERIA Z3+. But I have original back panel of XPERIA Z3. Can I put that back panel on Z3+?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Not 100% sure. Check Aliexpress.com for the part. They should ship to your region.
Punteggio 1
1 Commento:
Yes, I odered from Aliexpress.com and from ebay but problem is that those back panels are not good. They are unsticking and break very easy. I can't find oem back panel that is good. I have oem back panel from XPERIA Z3 that broke me and question is will it be OK to put that one on XPERIA Z3+?
da
You can check if the back panel aligns well by putting it in the back of the phone. Also, you wanna pay attention to the pins for the NFC antenna.
Punteggio 0
Aggiungi la tua risposta
Tomislav Matić sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 11
Tutti i Tempi: 555
