Salta al contenuto principale
Un tablet con sistema operativo Android rilasciato nel 2015, identificato dal numero di modello T10. Il Tagital T10 è un dispositivo touch screen con funzionalità Wi-Fi.
Optimizing Apps on Android Device
When I turn on device, it goes through the normal procedure, to the point when Android window comes up.. it slowly darkens to light as they do while loading the Apps.. then it goes to a screen that says " Optimizing Apps" . at this point it may start at Opting 1-10.. or 25 -77, or what ever never the same twice... (After many attemps) then it completes and goes back to Android Screen and just sit there.... eventually shutting down.. I have pushed the (reset) button with a paper clip.. it does nothing but start the cycle over..... Any help next to turning this into a Frisbee would be helpful Thanks... Jeff
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
Punteggio 0
Aggiungi la tua risposta
jeffntoni sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 23
Tutti i Tempi: 389
