Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Camera image shifts and will not focus in certain camera modes
After successfully replacing the aluminum body with an aftermarket one on my 7+, I tried the same thing with an iPhone 7 however I have come across a strange camera issue. This issue is evident in Panoramic and Time Lapse modes while in any other mode isn't present. The image on the phone is most shaky and distort when you first switch to the mode, and then it evens out a bit but keeps noticeably shaking even when the phone is itself unmoving making it difficult for the phone to focus. I suspect this has something to do with the optical image stabilization but really I don't know. I was wondering if any of you have any ideas what could be causing this or if you've experienced the issue yourself.
Questa è una buona domanda?
Punteggio 0
1 Commento
have you restarted the iPhone ?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
You need to replace the foam insert around the camera. Sounds like the lens can't move in and out.
Punteggio 1
Aggiungi la tua risposta
Mark Dunnam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 73
