Salta al contenuto principale
Si tratta di un fornetto tostapane in acciaio inossidabile da 4 fette. Il numero di modello si trova sul fondo del dispositivo. È dotato di un’unica altezza per la griglia e di un vassoio raccoglibriciole rimovibile.
Toast dial timer is stalling
The bottom dial ( the toaster timer) keeps stalling and won't turn off. It ticks for a while but stops after a while. The at times works if the toaster is upside down or it's back.
Do you need to change the switch? Or is there another way to fix it?
Questa è una buona domanda?
Punteggio 1
1 Commento
Happened to me too. It's a potential fire hazard when the mechanical timer doesnt shut off the oven.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Alfred,
I suspect you'll probably end up having to replace the timer, but you could try cleaning it. I would imagine there's a fair chance it may be gummed up with oils, carbon and all kinds of other volatiles from cooking.
Get yourself a can of electrical parts cleaner and spray the heck out of the timer. The cleaner will evaporate completely so there won't be an residue left in it when you hook it back up and try it. If there are any openings in the timer, use the red tube to direct the spray inside to wash it out.
Outside of disassembling the switch, which may or may not be possible, that would be my best suggestion.
Hope it helps; let us know how it goes!
Punteggio 1
1 Commento:
Thoughtful info, and so fast. Thanks!
da
Aggiungi la tua risposta
Alfred Assin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 43
Tutti i Tempi: 1,320
