Salta al contenuto principale
Xbox One Stereo Headset, numero di modello B00IAVDQCK. Rilasciate a marzo 2014, compatibili con Microsoft Xbox One. L'auricolare include padiglioni in tessuto over-ear, microfono a braccetto unidirezionale e adattatore rimovibile con controlli per il volume e il microfono.
Cable Plug-in Portion Destroyed
The cable that attaches to my Stereo Headset Adapter was chewed off by my dog. Besides that, the adapter itself, the headset, microphone are undamaged. Is there anyway to replace ONLY the cord portion of the device?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Although this guide doesn't show opening the cable side of the headset, the practice is the same.
Inside the cable portion of the head set the cable should be connected with some solder, simply heat the solder with a soldering iron and the old cable should come right off, and simply replace with a new one.
Or
you have just clip the cable above the damaged area and splice the cable with a new one, and cover with some heat shrink tubing or electrical tape, which means you don't have to open the headphone, but it's a bit ghetto.
Punteggio 0
Aggiungi la tua risposta
snow.surfer22 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 467
