L'Xperia Z1 Compact è lo smartphone con fotocamera di fascia alta di Sony. È simile al modello Xperia Z1, ma più piccolo e meno costoso. La sua caratteristica principale è un sensore della fotocamera da 20,7 megapixel. Al momento del lancio, i colori disponibili erano bianco, nero, rosa e lime.
Questo dispositivo può essere identificato tramite il numero di modello (D5503)
Customer came in with he's Sony Xperia Z1 Compact where the power button was not working and the volume buttons was barely working. So i told him i will order the flex cable part and get it fixed.
When i opened the phone i first checked if all that was needed was just to attach the plastic bit holding the flex cable into place a litle more. But still didn't work. So i went ahead and changed the flex cable.
After the change, the button still won't work. I checked and double checked my work and all seems normall. I also tried changing the button flex cable again.
Now the phone won't turn on and the buttons are not working.
Most important is to get the phone on without losing any files.
Anyone have any ideas, suggestions or solutions? it would be most greatfull.
I tried and looked at all the steps in your post and all seems well. The phone shows the Sony logo if i put in the charger but getting it to turn on as the power button won't work is not going well.
Open the sim card tray you'll find small red button besides tray press it using pen tip till handset vibrate. Now your phone will be turn on without losing your files.
2 Commenti
@oldturkey03 Thanks for your answer.
da Total Repairs AS Condividi
Did you find the root cause?
da Paul Carew Condividi
