Salta al contenuto principale
Guide di riparazione e assistenza per la 5D di terza generazione, una fotocamera DSLR lanciata da Canon nel 2012.
err 40 at power up
Hi,
my camera 5dmk3 power up correctly but it returns err 40. could it be an issue related to the PCB bottom or the DC-DC PCB, what's your opinion regard it?
I tried to load / access to your canon eos 5d mark 3 parts catalog , but it does not loaded. Is it in progress or is it not available?
Thanks in advance
Giorgio
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Soluzione prescelta
Giorgio Ba err40 is most commonly an electrical error. It can be related to the battery (first thing I'd replace) but also with the flex cables going to the DC-Dc board etc. Not sure why the parts catalog does not download for you. Added it on here==>>EOS 5D Mark III Parts Catalog
Punteggio 1
Hi Giorgio.
Did you find out what was wrong?
Rune
Punteggio 0
Hi,
Problem- A power malfunction have detected.
DIY- Turn off the camera and after 15-20 seconds power it on.
Punteggio 0
Was you in wet condition (moisture, raining, etc.) and after that camera´s went to faulty?
Punteggio 0
The bottom flex cable, between the bottom and main board, if installed backwards, can cause this error. The end with a B on it should be on the bottom board.
Punteggio 0
Aggiungi la tua risposta
Giorgio Ba sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 21
Tutti i Tempi: 4,655
