Salta al contenuto principale
Il Dell Dimension 3000 era un desktop di fascia media del 2004. Veniva fornito con 2 GB di RAM e con la possibilità di scegliere tra un processore Pentium 4, 4 HT o Celeron.
cpu fan stops turning
My cpu cooling fan needs a manual boost to start turning. What will a remedy be.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Herman Moothery , If you find yourself having to prod the fan to get it to spin, replace the CPU fan as it is sticking and probably faulty/worn out, new fan is inexpensive insurance to keep the CPU cool. Link below is just an example of a new fan that can be purchased, you can also do a search for perhaps better pricing. Good luck.
http://www.ebay.ca/itm/like/371612158491
Punteggio 3
It depends, some CPU's do not get hot in standby so the fan does not start turning until a specific degree of tempreature is reached. Then it is normal. But if the Fan is older then I would just buy a new CPU fan and then you can also choose to get a more quit version. There are a lot of CPU coolers out there.
https://geizhals.eu/?cat=cpucooler
Punteggio 2
Aggiungi la tua risposta
Herman Moothery sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 840
