Salta al contenuto principale
L'LG K7 è uno smartphone rilasciato da LG nel febbraio 2016 con sistema operativo Android 5.1.
Wifi calling connection not working.
My home is in a weak cell network location -- 1 or 2 bars at best. Although I have an excellent wifi network connection from my LG K7 to my home Comcast router, I'm unable to maintain a constant wifi calling connection at home. Other outside router connections to wifi calling seem to work well.
Questa è una buona domanda?
Punteggio 2
1 Commento:
I can get calls in but can't call out.just started last week off and on .now can't call out at all.my internet provider is frontier. I have basically the same problem as Edward Driscoll i have a strong wifi signal
da
Aggiungi un commento
2 Risposte
make sure you have data all the way off or it could bottleneck the speed of your wifi
Punteggio 0
I had the same problem and I just found the solution for me. I had to log onto my router (Lynksys connected to my Comcast modem) and disable IPv6. IPv6 uses longer IP addresses; LG K7 only supports the shorter addresses used in IPv4. So when I had both IPv6 and IPv4 enabled, my phone sometimes got sent the longer address, which caused it to not connect. Turning off IPv6 makes it work all the time now for me.
Hope this helps.
Punteggio 0
Aggiungi la tua risposta
Edward Driscoll sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 9
Tutti i Tempi: 1,546
