Salta al contenuto principale
Informazioni di riparazione e soluzione problemi per il Dell Latitude E6430. Questo portatile di classe business ha uno schermo da 14 pollici e utilizza un processore Intel Core di terza generazione. È stato annunciato a maggio 2012.
Laptop doesn't boot after upgrading RAM
Hi.
I tried to install 8GB RAM instead of 4GB. When I finished the replacement, I turned on my laptop, but the screen stayed black, no Dell logo or anything, no signs of booting at all (all the indicators were off). After 10-15 seconds it turned off by itself. After that the HDD indicator started blinking, and the other two indicators turned on.
Then I removed the new RAM and installed back the old modules. But I got the same problem - the laptop doesn't boot, there is no Dell logo. I tested both sets of RAM modules on my other laptop and they work.
How do I fix this?
P.S. I followed general recommendations and removed the battery before each procedure.
Questa è una buona domanda?
Punteggio 3
1 Commento
i know this is an old question and maybe for future users, they could get some use of this. im not exactly sure what the remedy is to this persons problem. i do know that i own a e6430 and after using it for over a year i dropped it so i went with the e6400 great laptop also. i do know for a fact that the 430 is capable of 8 gb of ram but not true with the 400 it is only able to take maximum 4 gb not sure if somehow thats related to your screen bios problem
da
Aggiungi un commento
5 Risposte
Soluzione prescelta
Turned out I was supposed to remove the CMOS battery (and press the power button for a 10 second) after upgrading the memory. It's described on the Dell website http://www.dell.com/support/article/us/e...
It works now!
Punteggio 4
4 Commenti:
I have the same problem when I tried to upgrade the RAM. Could you help me with instructions to remove the cmos battery on Dell latitude 6430u?
da
This option of removing cmos battery had ruined my system
Not helpful
da
omg thank you very helpful god bless
da
It's still failing to work, my screen still black. Even after removing CMOS battery....
da
Hi @albertchisu ,
Here’s a link to the service manual for your laptop.
Scroll to p.27 to view the necessary pre-requisite steps and then the procedure to remove/replace the coin cell battery. (This is the CMOS or RTC battery)
Punteggio 2
Can you connect an external monitor? This checks to see if you just knocked the video cable loose.
Do you hear any beeping? If there isn't any, its likely not the RAM.
Punteggio 1
2 Commenti:
I was very careful and didn't touch anything beyond the memory modules. It's not my first time, so I'm pretty sure I didn't cause any physical damage.
When I press the power button, it beeps, the DVD drive turns on, but that's it.
da
Just a single beep or a pattern of beeping?
I know this laptop well. The RAM slots are very close to the CPU. I would also suggest checking if that was knocked loose. I know you said you are very careful, but stuff happens.
da
I got my hands on a few of these . It looked likenthey belonged to a company and were wiped. No hdd. No ram. I bought rams and hard drive . Tried everything on these post and the laptops wont boot up. They turn on the fan comes on but the laptop shuts right off. No beeping nothing. When the fan goes off the HDD nd wifi light stay on(solid) and the battery light blinks…..someone pls help
Punteggio 0
4 Commenti:
Have you tried the steps above with the CMOS batery, etc.?
da
yes i tried and nothing
da
Could be why the company disposed of them.
Just a guess, RAM compatiblity?
da
I had the same problem.
And i put the old ram correctly in the second place . And press the shout down press for 10 s . And wait for 2 m with out battery. And start
da
I had a similar problem, and it turned out that the CMOS battery was dead. The CMOS battery allows the computer to maintain the BIOS memory, even when the computer is off. If the CMOS battery is dead, the CMOS won't respond to the boot command. I replaced the CMOS battery, I went through a start-up process for the BIOS, (because the BIOS had returned to its default condition,) and all was right with the world. I now keep a record of all BIOS changes. It took me a long time to figure this out, but a recently met a wise man who, changed his CMOS battery each year and had a dual parallel battery rig that let him change the battery, WITHOUT interrupting the electricity to the CMOS, and losing the CMOS settings. In normed use the CMOS battery lasts 1 or 2 years, but can go as long as six years, But when it dies, so does the computer (at least, until it is revived by serious effort). This may not apply this the specific "memory change" case, but, whenever components are changed, that puts stress on the CMOS battery, and that stress might kill an old CMOS battery Gerry Blodgett
Punteggio 0
Aggiungi la tua risposta
Serhij Sokolenko sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 23
Tutti i Tempi: 45,300
