Salta al contenuto principale
The LG G2 Sprint was released in September 2013. The LG G2 is a LTE capable smartphone running Android 4.2.2 with a rear power and volume button placement.
I think my screen display is broken
  • I can't see anything on the screen
  • Screen is black but lights up when turned on
  • Back light flickers
  • Everything still functions normally except for the display
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Was the phone dropped or did it get wet at all?
If it did not get wet then here is the Ifixit guide on how to repair the LCD screen/Digitizer (touchscreen) on your phone.
LG G2 Sprint Display Assembly Replacement
Here is a link to just one supplier of the part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. If you use them ensure that you have selected the correct part.There are others online that may suit you better.
http://www.etradesupply.com/catalogsearc...
If you find the repair too daunting to do yourself then I recommend that you contact 3 reputable, professional mobile phone repair services and ask for a quote for a repair. I suggest 3, that way if all the repair estimates are close you will have a truer indication of the cost of the repair. You should already know the cost of the replacement part.
Hopefully this is of some help.
Punteggio 1
Aggiungi la tua risposta
Renée Hewitt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 150
