Salta al contenuto principale
Il Samsung Galaxy S6 Edge+ è una versione di dimensioni maggiori dello smartphone Galaxy S6 Edge. Problemi di ricarica
Custom binary blocket by frp lock.
Questa è una buona domanda?
Punteggio 4
1 Commento
gianimiliardaru0 exactly what does this "Custom binary blocket by frp lock." mean? what do you see? What does it do? It will help if you clarify this.
da
Aggiungi un commento
4 Risposte
Risposta più utile
Enable OEM Unlocking before flashing any ROM. Flash the Stock ROM and follow this guide to Fix Custom Binary Blocked by FAP or FRP Lock.
Punteggio 2
Greetings,
do you still have the problem, if yes I got the solution and also the bypass for you :)
Update (21.01.2018)
FRP Lock is used against thefts, before FRP exist, people could just do a three button combo to factory reset your phone and sing in with their Google Account. Since FRP it shall make it harder for people bypass this, if you do such a factory reset it will ask about the previous Google Account used (that clearly thefts don't have). Hope this helped you to clear it out. It is possible to bypass this.
Punteggio 1
Turn off reactivAtion lock first.
Punteggio 0
Heading text
fap lock
Punteggio 0
Aggiungi la tua risposta
gianimiliardaru0 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 3,223
