Tranny stuck in reverse
How to take it out of reverse
Questa è una buona domanda?
@jpnegron , Sergio Angulo , If manual transmission, try having some one rock the truck back and fourth while you try shifting out of reverse. If it does pop out your clutch/pressure plate/master/slave cylinder may be worn/faulty/ or have air in hydraulic system not allowing release. If it will just not come out of reverse suspect a damage/bent shift fork inside tranny. Good luck.
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 8
Tutti i Tempi: 496
