Salta al contenuto principale
Guide di riparazione e assistenza per i tablet prodotti da Azend/Envizen.
SIMM card inside the tablet
The small inter part of the SIMM card broke off in the slot. What can I do to get it out?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
It's hard to say without being able to see it. I usually utilize a pick (VERY CAREFULLY) to try to pull the card out. Is it visible enough for you to take a picture?
-CW
Punteggio 1
3 Commenti:
Thank you so much for the information but the small card is not visible. You need a small flashlight because it at the bottom. The Geek Guy said he would need to take the back off.
da
Without a solution, I took it to the Geek Guys. They took off the back and took out the card. What a rip off. $20 to take off the back and investigate the problem then another $20 to remove the card. I will try to solve the problem myself next time with a pick.
da
If you do, just make sure that once again, you are extremely careful.
da
Aggiungi la tua risposta
Jtourre sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 578
