Salta al contenuto principale
Tablet da 8,9 pollici, sviluppato in collaborazione da Google e HTC. Rilasciato per la prima volta a novembre 2014, con sistema operativo Android 5.0 Lollipop.
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione prescelta
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
Punteggio 1
4 Commenti:
Just a quick update, my new battery arrived today, fitted it and booted first time.
da
Yay!!! Glad your phone is back to working condition :)
da
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
da
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
da
Risposta più utile
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
Punteggio 3
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
Punteggio 0
1 Commento:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
da
Aggiungi la tua risposta
David Jackson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 21
Tutti i Tempi: 529
