Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
coconut oil behind my phone screen?
Yesterday I dropped a small amount of coconut oil on my phone, my phone was shattered however and the oil has gone behind the screen and run, the place where the oil was spilt is blue and the running oil has turned white even when it's on low brightness. The phone still works fine but if I got my screen replaced would the oil disappear?
Questa è una buona domanda?
Punteggio 0
2 Commenti
As long as your phone still operates normally a new lcd should fix this. Your screen's lcd has layers or sheets to it and the oil most likely just got trapped in those layers. I might still have whoever works on your phone do a quick look over to make sure oil didn't get on the motherboard itself but I wouldn't worry too much about it.
da
I dropped coconut oil on my phone the oil got in speakers ...what can I do ...help
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Amy Nicholson , Find below link #1 will show how to remove the 6S display assy. for replacement and link #2 are available screen assemblies (life time warranty)which can be purchased at iFixit store. Good luck.
Sostituzione schermo LCD e digitizer dell'iPhone 6s
https://www.ifixit.com/Store/iPhone/iPho...
Punteggio 1
You shouldn't be worried like Stephen said the coconut is only trapped in one of the LCD layers and replacing the LCD would fix the problem.
Punteggio 0
Would rise work to take out the oil from the phone
Punteggio 0
Aggiungi la tua risposta
Amy Nicholson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 55
Tutti i Tempi: 11,950
