Salta al contenuto principale
Modello CR8030iE5; una radiosveglia con funzionalità iPod.
How to use the aux
How do I use the aux on this device
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
On this model, there's only an auxiliary audio out port located center on the back. Just plug headphones or auxiliary speakers in and your done. Just power up the radio. Theoretically, you could add a second jack and wire it up to the audio input pins on the dock connector inside for auxiliary input, though no pinout is provided to proof work.
Hope this answers that.
Punteggio 0
Plug a set of wired headphones or earbuds or plug in a speaker into the audio jack on the back of the alarm clock. It should mute the internal speakers of the alarm clock and play the audio from your alarm clock thru the speakers/headphones/earbuds.
Punteggio 0
Aggiungi la tua risposta
Jeremy Williams sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 1,136
