Salta al contenuto principale
Informazioni di riparazione e guide allo smontaggio per pentole a pressione.
Opening pressure cooker to replace LED board? How?
I need to replace the LED PCBoard on my electric pressure cooker as the LED display is broken. I managed to get the spare part from an appliance spares place, but now I have no idea where to open the Pressure cooker (easiest way), to swop out the old board for the new one. PLEASE HELP :-) - Cuisinart Electric Pressure Cooker CPC-600 or AEG/Electrolux EPC600.
Questa è una buona domanda?
Punteggio 2
2 Commenti
Where did you get the LED board?
Thanks!
da
why my presiure cooker have so load terrible sound when turn
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
I just can't find any teardowns or repair guides on this. These people sell the parts and have a toll free number and may be able to assist you: http://www.ereplacementparts.com/cuisina...
Punteggio 2
You have to undo all the screws from inside and slide the outer case off there is a screw underneath a label and the front panel peel off label there should be to screw underneath at the top when you have done that there are 4 screws holding the panel on for the led circuit board I have done one my self so please put all the screws in a safe place as I did so you don't lose them I hope this helps you
Punteggio 0
2 Commenti:
I hope this helps you out
da
where can you get the led display Pressure king pro 5l
da
Aggiungi la tua risposta
Phillip sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 30
Tutti i Tempi: 3,945
