Salta al contenuto principale
Can switching regulators cause interference on wifi based circuits?
I read that buck and boost converter due its switching mode produces too many noises compared with linear regulators but it is more efficient.
Can those those noises cause interference on boards with wifi chips on it?
How would be a good way to measure how big would be such interference at the point to determine that it is worth to use a linear regulator even without power efficiency?
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi, This might be a good starting point.
http://www.ti.com/lit/an/slva219a/slva21...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I am not an electronics engineer but it is correct to say that SMPS are inherently noisy. Linear Regulators, when properly designed are not.
That said, applying proper filtering and EMI reduction are key to proper product design. A good example is smartphones. They have multiple SMPS cohabiting with WiFi and other radio frequency devices all on a single (and tiny) pcb.
Generally speaking, PS requirements are based more on power and heat dissipation than EMI because you can always filter out noise but you can't eliminate heat.
Not sure if this helps or not...StackExchange or EEVBLOG Forum is probably a better place for this question.
Punteggio 2
Aggiungi la tua risposta
AmandaLi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 138
