Salta al contenuto principale
Lenovo ThinkPad X220. Si tratta di un portatile business introdotto nell'aprile 2011. Questo notebook da 12,5″ può essere configurato con un processore Intel Core i3 da 2,1 GHz fino alla fascia alta con un processore Intel Core i7-2640M da 2,7 GHz e grafica integrata Intel.
fan replacement help needed
hi
my computer keeps overheating and figured i need to replace the fan.
bought a new one made sure everything is in order but i can find a guide to actually change the fan.
can anyone help my with changing it?
Questa è una buona domanda?
Punteggio 0
1 Commento
sorry i didnt mention the computer is a lenovo x220 thinkpad
da
Aggiungi un commento
1 Risposta
Risposta più utile
Yoav Sharaby, Below are links showing the disassembly process for your Think Pad to enable you to change the fan from the systems board. 1st link is a video and 2nd link is the Lenova x220 disassembly manual. , Good luck.
https://www.youtube.com/watch?v=euyItfKn...
http://www.laptoppartstore.com/uploads/9...
Punteggio 4
1 Commento:
hi
I have used the video on the link you sent me but he does not show how to actually replace the fan he stops right before that step so ill try using the computer manual instead.
thank you
da
Aggiungi la tua risposta
Yoav Sharaby sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 23
Tutti i Tempi: 2,938
