Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
touch screen not working after screen replacement?
Hi everyone! i have a big problem. I've just replace the screen of my huawei p9 (it has been a VERY HARD work), when i've finished all, i connect all the cable, i turn on the phone, the screen work but the touch screen doesn't. What happen? how can it not work? i've done everything right...
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
hi, have you solved? Did you understand what the problem is?
I have the same problem and I am very worried because the phone is not mine but my brother and he is convinced that the touch screen does not work because I have not been able to fix it. I do not want problems with him. Please reply
Punteggio 0
Resurrecting something from the dead here but I’m seeing issues with a P9 myself. Touch is working but occasionaly unresponsive to swipes (especially left-to-right) or misinterprets swipes as touches.
Googling leads me to believe there’s a grounding problem or something. Or perhaps the part is just bad. I’ll try insulating the screen from the frame and clean the pressure contacts to see if it helps and update this with any new info.
Punteggio 0
1 Commento:
Hi... Any update?
da
Aggiungi la tua risposta
apriliamx5535 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 19
Tutti i Tempi: 2,304
