Salta al contenuto principale
The Canon Vixia HF S10 is a 2009 Camcorder with an 8 Megapixel Full HD Image Sensor and a High Resolution Recording. This camcorder also has a Dual Flash 32GB Internal Memory.
How to open lense cover
Hello,
here is my problem my camera dropped and now I hear like some motor is stuck inside where lense is. The camera wont turn off unless I remove battery but when I place battery in I can turn on and the stuck motor start again. How cn I take appart the cover around lense to see what is going on?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Thank you, I will try this instructions in other case I will need to take it to service.
da
Wish there was detail on removing the lens cover. Seems like a great start.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Use this guide to open it up:
Canon Vixia HF S10 Camcorder Power Button Replacement
Punteggio 2
Exactly same problem!
I'm trying to go near the optical - meccanic parts.
Regards.
Maurizio
Punteggio 0
Aggiungi la tua risposta
Mojca Jan Life diet sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 3,137
