Salta al contenuto principale
Macchina per caffè rilasciata nel 2013.
Why does my coffee taste bad?
The coffee I brewed in my Keurig has a bad taste to it and I noticed some small beans in the cup as well. I've been using this model for years now and recently I've noticed an unusual taste to the coffee.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
If your coffee has a metallic taste to it or has coffee grounds in the cups, then the Keurig will need to be cleaned. To clean the brewer, fill the water tank on the left side with a mixture of white vinegar and water. Now keep making hot water with the Keurig so that the mixture keeps going through the system. This should get rid of any build up inside it.
Punteggio 1
Aggiungi la tua risposta
michelinval sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 22
Ultimi 30 giorni: 43
Tutti i Tempi: 23,310
