Salta al contenuto principale
Una fotocamera digitale progettata e prodotta da Sony nel 2012. Una fotocamera da 18,2 megapixel con Wi-Fi, GPS e uno slot per schede di memoria.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Questa è una buona domanda?
Punteggio 1
2 Commenti
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
da
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sostituzione della scocca esterna della Sony Cyber-shot DSC-HX20V
Punteggio 4
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 14
Ultimi 30 giorni: 53
Tutti i Tempi: 1,807
