Salta al contenuto principale
Prima generazione della SLK, conosciuta anche come piattaforma R170.
How to add engine coolant
where to add coolant
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione prescelta
Keith, open the hood of your vehicle locate the coolant reservoir (link below will show picture of reservoir) normally mounted on rad cradle or inner fender well, look at markings on translucent area of reservoir to determine level of coolant. If coolant shows low or empty, when engine is cool remove reservoir cap and add specified coolant till at a acceptable level. If you had to add a lot of coolant to get it to correct level, you may have a leak, in this case it may be wise to have a good technician have a look and pressure test cooling system, diagnose and estimate repair if required. Check the attached links,instruction and guide, Good luck.
http://www.ebay.com/itm/01-02-03-04-MERC...
http://www.slkworld.com/slk-r170-class-d...
Punteggio 4
3 Commenti:
Note: I would suggest checking the coolant container before adding, to see if the MB coolant is premixed (diluted); if it's not premixed, add a 50-50 mix of concentrated coolant and distilled water.
da
I replaced a coolant hose and need to add coolant but don't know where to add it at
da
Btw does anyone know what coolant is the correct one for the 4 cylinders ? Just knowing color would be good.
I have a 230Kompressor. Cant see the stuff without needing to put in a dipstick etc.
da
Aggiungi la tua risposta
Keith Vines sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 78
Tutti i Tempi: 16,575
