Salta al contenuto principale
Informazioni per la riparazione delle lavastoviglie Whirlpool.
Error code E2 F2
Whirlpool W10632081A dishwasher error codes
Questa è una buona domanda?
Punteggio 6
6 Commenti
No leak, no corrosion on my unit, put dielectric on contacts anyway everywhere. Nothing helps, still have the e2f2 code. Gonna buy a new dishwasher tomorrow :(
da Condividi
The mother board replacement was about $60 and easy to replace
da Condividi
E2 and F2 error code on a new whirlpool dishwasher model wdt730pahv0
da Condividi
Replaced control board, replaced interface! Still have the same dam problem. F2E2
da Condividi
Last time this happened i replayed the display module and Voila! This fixed it. Now it has happen again in less that 5 months. WTF. Going to try the W40
da Condividi
Mostra 1 altri commenti
Aggiungi un commento
4 Risposte
Soluzione prescelta
William, As a first step turn power off to machine for 10 minutes and see if it resets. Whirlpool gold series dishwasher error code e2 f2, means main control board is not getting correct signal from the user interface. Turn off power/breaker, remove screws holding inner door liner, remove liner and check/secure/clean all wire connections from front interface and main control board. If all good and still not working the user interface is probably faulty and has to be changed. Check the attached link,instruction and guide on how to access control and wires, Good luck.
https://www.youtube.com/watch?v=rZMU8T7N...
Punteggio 16
13 Commenti:
Thank you so much for posting the link!
My 4 wire contact to the main board was corroded so I de-energized the breaker, then I cleaned the wire contact by soaking in salt/ vinegar solution for two minutes, then baking soda/ water to neutralize. Lastly when i hooked it all up togeather, i added dielectric grease to prevent further corrosion.
God bless!
da Condividi
This worked perfectly for us! Thank you SO much!
da Condividi
Turned off breaker for 10 minutes and it did reset. Checked connections and they seemed fine with no visual corrosion or loose connection. I noticed the codes after my 15 amp breaker trips for living room lights? It’s a rent house so I’ll have landlord send someone to check out breakers. Thanks for the post!
da Condividi
Great info, also did as McHales and cleaned up the contacts, working again! Thanks a lot
da Condividi
Thanks a mill. This helped and saved me a bundle. As always give help, get help. Thanks Guys
da Condividi
Mostra 8 altri commenti
Thank God that this worked. I could see that water and I think coffee had gotten in along the top edge from a counter top spill. There was water spots and rust above and below the control panel and circuit board. I could see corrosion on the teeth of the circuit board where the power connectors snapped on. A light sanding with a pink eraser, coated with dielectric grease, reassembled and it worked.
To clean properly you need to get the circuit board all the way out of the plastic housing. Go slow and be careful undoing all the clips and tabs.
To prevent future ingress of water from the counter top I used some foil tape to seal the edge between the door and the top edge of the control panel display.
Punteggio 2
After a pump failure covered by warranty we experienced a blown mother board also covered by warranty. Because of both issues we were without a dishwasher for 4 months due to parts on back order. Today 3 weeks after the last repair we received the e2 f2 error code. After reading this thread and dreading calling the warranty company again....I followed the steps described in the thread to clean the connector to the mother board. Boom it worked and momma gets clean dishes. It was maybe a 30 minute fix.
Punteggio 1
I took apart the dishwasher and everything looked good. leaned my control panel. No luck. Bought a new one and replaced it. Put everything back together. Still E2 F2. So it is probably the motherboard? This happened after a countertop spill.
Punteggio 1
Aggiungi la tua risposta
William sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 31
Ultimi 30 giorni: 189
Tutti i Tempi: 119,417
