Salta al contenuto principale
notebook a basso costo con potenza di base anche per il gaming, include i modelli G50-30, G50-45, G50-70, G50-80.
what's wrong with the screen
the screen of my laptop turns white then black but the laptop is functioning i can see something through the small top bar on the screen .whats wrong with it and how can i fix it? you can see by this https://www.datafilehost.com/d/f7cea510 image
Update (09/17/2016)
Immagine
Immagine
its a lenovo g50
Questa è una buona domanda?
Punteggio 1
1 Commento
put the picture on here and we will see if we can help you, what model is the laptop?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Connect an external monitor to the laptop and see what the display is like on it.
If the external monitor display is OK then you either have a faulty video cable, faulty video cable connection at either end or a faulty LCD screen.
If the external monitor display is the same as the laptop screen display then you have either a GPU fault or a motherboard fault.
Punteggio 1
Aggiungi la tua risposta
thendo Ndou Malakate sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 746
