Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Questa è una buona domanda?
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 72
Tutti i Tempi: 4,359
3 Commenti
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
da Khemchand Ramcharan
Re-aligning print heads doesn't solve the problem....
da Tracy Lloyd
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
da jayeff
