Salta al contenuto principale
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
23 Domande Visualizza tutte
Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Questa è una buona domanda?
Punteggio 2
3 Commenti
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
da
Re-aligning print heads doesn't solve the problem....
da
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Punteggio 2
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Punteggio 0
Aggiungi la tua risposta
Khemchand Ramcharan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,328
