Salta al contenuto principale
Sony Xperia Z3 Compact pubblicato a settembre 2014.
After replacement: back Camera still not working.
I replaced the camera because I thought I had a hardware related issue (black screen). But even after replacing it, the screen stays black. I found many people online who have the same problem (before replacing the back camera, mind you). Any suggestions on how to find out, whats causing the problem? When I start the camera app I hear a clicking noise and than that's it.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Here is a solution for all those who still struggle with this issue:
Risoluzione problemi di fotocamera nera / assenza di immagine su Sony Xperia Z3 Compact
Punteggio 0
1 Commento:
Can you explain what this is that you are fixing and where you can get one as the top one is missing from my motherboard
da
Punteggio 0
Aggiungi la tua risposta
Frantastico sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 2
Tutti i Tempi: 452
