Why is my laptop has vertical lines and the screen giggles
My laptop has vertical line at upper portion and the screen keeps on giggling , is there a solution to this problem??
Questa è una buona domanda?
@dhang based on your description alone, it sounds like a broken LCD. There is no repair for that, you will have to replace it. To verifiy that suspicion it will help if you post some images of what your screen looks like with your question. Use this guide for that. That way we can see what you see. Also, let us know what model your ASUS is.
While I agree with @oldturkey03, that pictures and the model number would be helpful, My initial thought is that what you're seeing is the result of a loose or bad video chip on the motherboard. From my experience, this is a common fault with Asus laptops, especially some of the older ones. While the teardown of a laptop can be a daunting adventure, it is something that is done thousands of times every day. Repairing the motherboard is quite another story. Without the proper tools, you can inadvertently do more harm than good. That said, unless you have those tools, I would recommend replacing the motherboard. Provided that is you have determined that to be the true cause of the issue, and not a truly defective or broken LCD.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 454
