Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Data Recovery Broken iPhone
Somebody please help! I recently dropped my iPhone into water and when I pulled it out, it was black and the dot next to the front facing camera was red. I haven't backed up any photos since March and I really need the pictures I have taken since then. I've tried software to recover them, but most won't recognize my phone when I plug it into my PC. How can I get it to recognize my iPhone? I seriously need those pictures. Somebody please help!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Hi there,
Tom Chai is right, in order to access your data/photos, the phone has to be semi-functional.
Water damage can be pretty nasty; it causes corrosion on the boards and shorts your circuits. Your best bet is to read and follow the steps on these guides in order to bring your phone to life enough to recover the photos: Riparazione danno da liquidi iPhone
Electronics Water Damage
Good luck!
Punteggio 4
Risposta Più Utile
Repair the original phone to the point that it can boot up, unlock and connect to PC via USB, or have wifi so you can back the data up through wifi. Other than that, nothing else can bring back the data.
Punteggio 4
1 Commento:
i agree with Tom ... unfortunately if you cannot the the original logic board to work, the data inside is lost :(
da
Can you connect your old phone to your PC with USB now? If you could, maybe you could try to use data recovery software to help you to recover your data, including photos, contacts, etc, from your phone without any backup. if you are a iPhone users, read this article to learn how to recover data from water damaged iPhone, while read this to know how to if you are a Android phone user, try to find other related article of this website to help you based on your situation!!!good luck to you.
Punteggio 0
Best advise for future - do a backup! iCloud is super comfy for apple devices.
About extract the data- try this
They helped me ones, after i dropped my iPhone in the pool , phone is dead but i have all my contacts and photos at least.
Punteggio 0
1 Commento:
It was written in 2016
da
It may be some hardware related causes, you should check the connector first. Here is a guide on how to recover data from a water damaged iphone. Hope it helps.
Punteggio 0
Aggiungi la tua risposta
Lydia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 371
