Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
using iPad with external power supply only
Hi,
Can you help please. I want to use iPad 3 without a battery, removed the battery and want to run on the charger power only... tried but it's not working... is there a tweak needed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Will not work. The battery powers some of the chips directly, also the device constantly checks the battery status bus.
Punteggio 2
1 Commento:
Thanks a lot Tom,
What if I connect a 3.7V battery to the battery terminals...
da
Aggiungi la tua risposta
Adham sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 134
